This behavior has been reported as a bug in LabWindows/CVI 2020. There are two workarounds that you can use in order to get the expected output text in a text box control:
- Add additional "\n" as needed to replicate the behavior in previous versions of LabWindows/CVI.
- Use the "SetCtrlVal(panel,control, text)" instead of the InsertTextBoxLine method.
