The PXIe-5668 hardware is a Vector Signal Analyzer or VSA. This device is comprised of three subsystems:
- PXIe-5606: RF Signal Downconverter.
- PXIe-5624: intermediate frequency (IF) digitizer.
- PXIe-5653: RF Analog Signal Generator synthesizer/local oscillator (LO) source module.
The error indicates there is a potential issue with the LO, the PXIe-5653. This card has strict requirements for clock accuracy and stability. Therefore, if you are exporting its clock to another device, and this other device is having issues in its clock circuitry, you will potentially get this error.
In this case, it is recommended to replace the device that is receiving the clock from the PXIe-5653 with another one.
