When using the niscope API, inserting any documented value for the niscope.Session.output_clock_source property always returns the following error when trying this on the PXI-5922:
niscope.errors.DriverError: -1074107489: Source terminal to be routed could not be found on the device.
Make sure the terminal name is valid for the specified device. Refer to Measurement & Automation Explorer for valid terminal names.
Source Device: PXI1Slot4
Source Terminal: Internal10MHzOsc
Destination Device: PXI1Slot4
Destination Terminal: ReferenceClock
