This issue is predominantly seen when the PATH environment variable and its subdirectories are added as search directories in the Search Directories configuration. However, it can also occur by adding a folder that includes a large number of files and subdirectories.
If TestStand can still open, you can deselect those folders to improve the loading time. You may also consider navigating to
C:\ProgramData\National Instruments\TestStand 2021 (64-bit)\Cfg or
C:\ProgramData\National Instruments\TestStand 2021 (32-bit)\Cfg, depending on the TestStand bitness, and removing the
SearchDirectories.cfg file before relaunching TestStand to fix the issue.
