Error -25 Transaction Failed in LabWindows/CVI When Using DDE
Updated Nov 2, 2023
  • LabWindows/CVI
  • I am using LabWindows/CVI™ as a DDE client and communicating with a 3rd party DDE server. I keep receiving error -25. How can I fix this?
  • I receive a "Transaction Failed" error in LabWindows/CVI when I call ClientDDEExecute for some of my DDE Topics. Other times it works. Why does this happen?
  • My DDE communication in LabWindows/CVI used to work. Now that I've upgraded my software, I keep receiving the error below:
Error -25: Transaction Failed
This error can be caused by a number of factors. Follow the steps below to narrow down the possible causes and resolve the error:
  1. Install LabWindows/CVI 2020 f2 or newer if an older version is currently being used.
    • Several bugs that effect DDE communication were reported in LabWindows/CVI 2020. These were fixed in version 2020 f2.
    • Refer to LabWindows/CVI 2020 Known Issues for more information.
  2. Verify that a connection to the DDE server can be successfully made.
  3. If the error occurs at ClientDDEExecute, check that the syntax for the command string is correct.
    • Refer to the DDE Server's User Manual to determine that the LabWindows/CVI command matches the exact syntax required for the DDE Topic.
  4. Ensure that the DDE connection is properly closed before the code completes execution.
  5. If LabWindows/CVI is communicating with a 3rd party DDE server, reinstall the 3rd party software.
    • This will repair any damaged or corrupt 3rd party software files.
If the error remains after following the steps above, consider using a software tool that enables DDE tracing. For example, those with a license for Microsoft Visual Studio can use Microsoft's Spy++ tool. This will highlight the messages that are exchanged between the client and server, which can be useful for troubleshooting the exact point of error.
