Multiple Square Wave Generator In LabVIEW FPGA Generate Unexpected Output
Updated Jun 6, 2023
  • LabVIEW FPGA Module
Inconsistent signal generated when running multiple Square Wave Generator Express VI inside a while loop in LabVIEW FPGA.
Executing multiple Square Wave Generator Express VI inside a While loop will generate an unexpected pulse pattern.
As a workaround, execute Square Wave Generators inside Timed Loop (SCTL) to generate a consistent pulse train.
Select single-cycle Timed Loop as the execution mode in the Square Wave Generator properties.
