Error -19034: TestStand Deployment Utility Unable to Execute Files
Updated Mar 7, 2025
  • TestStand
  • I keep seeing error -19034 when using TestStand™ Deployment Utility. How can I fix this?
  • I am trying to create a deployment image using TestStand Deployment Utility, but the following error occurs:
"-19034 Unable to execute the following files:
TestStand - Read Linker Info from File LV 8 or Above.vi"
This error can be caused by a number of different factors. To resolve it, follow the troubleshooting steps below:
  1. Ensure that TestStand is using the Run-Time version of LabVIEW.
  2. Verify that LabVIEW is not running in the background before creating the deployment.
    • This will ensure that existing VIs are not being held in memory.
  3. If multiple versions of TestStand are installed on the host PC, change the active version to re-register the TestStand API VIs.
    • Open the TestStand Version Selector application.
    • Select a different version of TestStand under the Installed TestStand drop-down menu and click Make Active.
    • Revert back to the original active version of TestStand to re-register it.
  4. Mass compile all LabVIEW VIs to ensure that the deployed VIs are using the correct version of LabVIEW.
  5. Open the TestStand Deployment Utility Build Log to find additional details about the error.
    • To create a Build Log, click the Save Log button at the top of the Build Status tab of the Deployment Utility.
    • Investigate the Build Log and Status Log files to determine the source of the error.
  6. Navigate to the directory of the problem VI and verify that the VI can run independently of TestStand.
    • The error shown above refers to a problem with TestStand - Read Linker Info from File LV 8 or Above.vi, which is a part of the Distribution VI.llb library located in C:\Program Files (x86)\National Instruments\TestStand <version>\Components\Tools\Deployment Utility\DistVIs\<version>.
  7. If the problem VI is broken or missing, reinstall TestStand.
  8. If you're using LabVIEW 2023 Q3 or later and your VIs contains Channel Wires, LabVIEW is crashing when executing TestStand - Read Linker Info from File LV 8 or Above.vi for VIs containing channel wires.
    • As a workaround, you can use LabVIEW 2022 Q3 or older. If you have multiple LabVIEW versions installed, ensure 2022 Q3 is last launched (making it the active version) before opening the TestStand Deployment Utility (TSDU) and then perform the build.
    • Replacing the channel wires by other loop communication mechanisms such as variables, notifiers and queues will also solve the issue.
