To enable the Installer Options tab, follow the steps below:
1. Verify that the MSI-Based Installer is selected as the Output type under the Mode tab, as shown below.
- If Deployable Image Only is selected, the Deployment Utility will only move the deployment files into the specified image directory.
- The MSI-Based Installer creates an installer in addition to a deployable image. Refer to Mode Tab - TestStand Deployment Utility for further details.
2. If the tab remains inaccessible after changing the Output type, uninstall and then reinstall TestStand.
