LabVIEW 2021 and 2021 SP1 Scale and Layout Issue
Updated Feb 16, 2024
  • LabVIEW 2021 SP1
  • LabVIEW 2021
LabVIEW 2021 or 2021 SP1 shows up with the wrong scaling as shown below.
This is a known issue, you can upgrade to LabVIEW 2022 Q3 to avoid this problem. Additionally as a workaround you can manually set the DPI settings:
  1. Right-click on LabVIEW icon and then select Properties>>Compatibility>>Change high DPI settings.
2. Check Override high DPI scaling behavior and on Scaling performed by: select System.
