I use the NI SystemLink Test Monitor Client model plugin to upload TestStand results to SystemLink. While running sequences in TestStand, I occasionally need to press the
Terminate button. If I repeatedly press it (a double-click, for example) the sequence results show up as
"Running" on SystemLink, even though TestStand has finished the execution on the test system. After 24h hours the Status on SystemLink changes to
"Timed Out".
That represents an inconsistency in my test results. How can I prevent this from happening?
