Note: NI does not recommend LabVIEW MathScript Module functions for new designs. Refer to www.ni.com/migratemathscript for information and recommended alternatives.There is no equivalent function for the right matrix division in LabVIEW, so you have to use the equivalent formula used by the MathScript code to perform this operation.
c = rightdivmx(a, b)
The infix notation for rightdivmx(a, b) is a/b. rightdivmx(a, b) is equivalent to leftdivmx(b', a')'. If you want to replicate the a/b mrdivide you can also use a*b' which is equivalent to a/b.
LabVIEW does a traditional point-by-point divide for the matrices when using the
divide function, so you have to use the full formula in order to get the mrdivide result.
