Time Reference for the Timing Functions Palette
Updated Oct 2, 2025
I need to create a timer and I would like to know what is the time reference for the Timing Functions in LabVIEW.
LabVIEW uses the operating system (OS) time as time reference. So, if you want to know the accuracy of the timing, you should check it from your OS.
NI does not provide calibration sheets to ensure the timing of its VIs because this is dependent of your OS.
