I am using USRP-2944 with Simple Tx and Rx Streaming example to measure the power spectrum, the Tx channel will generate a finite signal and the Rx channel will measure the output signal from the same USRP. I found out that the result for the power spectrum is not stable at the Rx channel, I have tried many times by changing the USRP device, RF channel, central frequency, and transmit power, but the same issue happen.
