Installing the NI Digital Pattern Editor
Updated May 14, 2024
  • Package Manager
  • NI-Digital Pattern Driver
Digital Pattern Editor is an application for testing and de-bugging pattern-based digital devices. It can be used to view, create, modify, and debug pin and channel maps, specifications, levels, timings, patterns, register maps, source waveforms, and capture waveforms.
This article explains how you can install the Digital Pattern Editor.
Install With NI-Digital Pattern Driver
Digital Pattern Editor can be installed along with the NI-Digital Pattern driver as explained below :
  1. Download NI-Digital Pattern driver from the driver download page.
  2. Run the installer and select NI Digital Pattern Editor and Compiler when prompted to install additional items as shown in the screenshot below :
Installing NI Digital Pattern Editor with NI Digital Pattern Driver
Install Separately Using NI Package Manager
  1. Open NI Package Manager and navigate to the Packages tab
  2. Search for 'Digital Pattern Editor' ; uncheck the Products Only checkbox as shown below
  3. Select the NI Digital Pattern Editor and Compiler package and click the Install button
NI Digital Pattern Editor Package Installation through NIPM
Next Steps
Refer to Getting Started with Digital Pattern Editor for more information about the editor.
