Error -1074100463 occurs when I use PXIe-5830
Updated Mar 7, 2022
  • PXIe-5830
When I tried to test using PXIe-5830 in RFmx SFP, I got the error -1074100463 like below:
NationalInstruments.RFmx.SpecAnMX: -1074100463: Another session with a different Reference Clock source is using the Reference Clock. Ensure you configure all sessions for a device to use the same Reference Clock source.
If you using PXIe-5831, you should check the cable connection. If REF IN of PXIe-5820 and REF OUT of PXIe-3621 is not connected, the error may occur because they are not the same reference clock. Make sure the cable connections are as shown below.
