I am using NI PXIe-6593 housed in PXIe-1071 in a simple loopback using QSFP28 cables. When running the default NI shipping example project from NI Example Finder, the ‘Continuous Stream Writer’ VI (i.e., Tx end) works. However, I face the following error when running ‘Finite Stream Reader’ VI (i.e., Rx end).
Error -1074100508:
Stream experienced an unhandled interruption due to a buffer underflow or overflow. Your transfer may be truncated
