Displaying Only the Latest Results When “On-The-Fly” Report Is Disabled in TestStand
Updated Oct 18, 2024
  • TestStand
I want to display only the latest results in the TestStand report without enabling the On-The-Fly Reporting. Is it possible?
To enable the Only Display Latest Results option, you must initially enable On-The-Fly Reporting (Enable On-The-Fly Reporting or Logging in TestStand).
However, if you disable On-The-Fly Reporting, the Only Display Latest Results option will also be automatically disabled.
