Can Analysis Automation Stop Python From Running Rest of Script When There Is an Error?
Updated Jun 20, 2023
  • DIAdem
  • Analysis Server
Programming Language
  • Python
I am running a Python script in an Analaysis Automation procedure, but would like for the script to stop running when there is an error. Is there a way to achieve this?
There are several methods you can use to achieve this. Following are some of the options:
  • Use RaiseError for ContextRun method to terminate the On_Run_AnalysisProcedure event with an error message without executing further commands. This will abort the script with an error message that includes the error number and text specified in the script.
  • Use (external link) Python's syntax for raising exceptions to raise a ValueError. This will throw a ValueError exception with the error message text.
  • Use LogError for ContextRun method to create an error and mark the file in the Analysis Server as "failed," and include (external link) Python's system-specific function , sys.exit([arg]), to terminate and exit out of Python. The LogError method itself only logs the error and does not stop the script.
