Customize the Measurement Probe Display in NI Multisim
Updated Nov 8, 2022
  • Multisim
This article explains how to customize the measurement probe display within NI Multisim.
  1. Double-click the probe to open the Probe Properties dialog.
  1. Select the Parameters tab.
  1. Click the checkbox besides Show to hide or display everything.
  1. Next click on the cell underneath the Show column to individually select which item to display.
  1. Click Apply then OK to close the Probe Properties dialog. 
Depending on what you changed, the probe display window may be too large, if so, complete the following steps:
  1. Click on the probe display and there will be blue vertices around the border.
  1. Click on a vertex to adjust the display area.
