Archived:Update FRC Dashboard for 2019.2 Update Suite
Updated Feb 4, 2022
  • LabVIEW Software for FRC 2019
The 2019.2 First Robotics Competition (FRC) Update Suite included a number of changes to the system, without this update, there may be problems when trying to connect to the FRC robot on the field.
This guide steps through the update process, you will need the most recent version of the NI FRC Update Suite installed on all of your computers (your development machine(s), as well as the computer you use during matches).
  1. Update your Dashboard to the newest version.
    1. Download the 2019.2.2_LVDashboard.zip file that is attached at the bottom of this document and extract it in your hard drive.
    2. Close all running applications in your computer (including LabVIEW, the FRC Dashboard and FRC Driver Station).
    3. Copy the Program Files (x86) folder
    4. Navigate to your C:\ drive and paste the Program Files (x86) folder. Select the "replace" option to merge the contents and update the relevant VIs.
      1. Note for international teams: if your computer is not in English, copy the contents inside the Zip file's Program Files (x86) folder to your local Program Files (x86). (For example: Archivos de Programa (x86), in Spanish).
  1. If you're using the default Dashboard no other modifications are needed.
  1. If you are using a custom LabVIEW Dashboard:
  1. Open your Dashboard project in LabVIEW to reload the updated VIs.
  1. Add a way to check the robot's IP: use the path C:\Program Files (x86)\National Instruments\LabVIEW 2018\vi.lib\Rock Robotics\WPI\Dashboard to open a File Explorer window, and drag/drop the file WPI_DashboardGet Robot IP.vi directly to the Dashboard Main Block Diagram. Wire the required input, called the Notification Refnum, as shown below. 
  1. rtaImage (1).jfif
    1. Rebuild your dashboard by right-clicking on the Build Specification in your Project Explorer and selecting Build
    2. Navigate to where you saved the new executable file (you can select the Explore option when the application finished building). Copy the new Dashboard.exe file over to the C:\Program Files (x86)\FRC Dashboard directory, replacing the existing one.
  2.  If you keep having troubles with your camera, please continue troubleshooting with the instructions located in the following document: Robot Camera Images Not Appearing in FRC Dashboard
Next Steps
You can find more information about creating and building a dashboard here: FRC Dashboard Tutorial
For more information about the 2019.2 Update Suite, the release notes can be found in two places:
  1. Within the Dashboard update zip file
  1. In the article: FRC Update Suite 2019.2 Release Notes
