Error -200463 Executing Digital Output Using DAQ Assistant
Updated Sep 27, 2024
  • NI-DAQ™mx
Below error when I am executing digital output using DAQ Assistant.
This error occurred because the boolean array connected to DAQ Assistant is not initialized. You can initialized array by specifying the element on the last index either to TRUE or FALSE.
