File Dialog Box Extension List Is Empty When Calling From LabWindows/CVI
Updated May 22, 2025
  • LabWindows/CVI
When I try to open the file select dialog box with a custom file extension, the Windows 7 File Explorer extension list is empty. This happens only on the production machine it works fine in the development machine.
The issue comes from the windows file explorer File name extensions settings, when it is not checked the File Explorer won't show extensions and LabWindows/CVI will not be able to show the list of extensions. In order to overcome this issue check the File name extensions box from File Explorer > View > File name extensions, or instead of
FileSelectPopupEx (directory, "*.xml", "datafile",
                               "This is a File Select Popup",
                               VAL_SAVE_BUTTON, 0, 0, filename)
, use
FileSelectPopupEx (directory, "xml file (*.xml);", "datafile",
