Error -301139 Using the ECU Measurement and Calibration Toolkit
Updated Apr 28, 2023
  • ECU Measurement and Calibration Toolkit
  • When using the ECU Measurement and Calibration Toolkit with LabVIEW to use ASAM (.A2L) database files, while using a interpolation table for scaling, LabVIEW gets the following error:
Error -301139 occured at MC Read NChan 1Sampl 1D Dbl.vi
ECU Measurement and Calibration Toolkit: Scaling: No scaling is defined for one or more internal values. The respective physical values have been replaced by zero or empty strings.
  • When using the A2L Viewer to view an existing A2L databases, using interpolation table for scaling, the Diagnostics Error List has the error code -301146 with the description:
ECU Measurement and Calibration Toolkit: The scaling defined for this object does not support the requested property; the scaling factor or offset cannot be derived from the current scaling. It is not linear, following the schema AX+B, where A is the scaling factor, X is the raw data, and B is the scaling offset
The measured data in the XCP command needs to be within the range given by the interpolation table, as there is no scaling factor for the interpolation.
