TestStand Program Runs Slower in Deployment Than Development Environment
Updated Nov 2, 2023
  • TestStand
System
  • STS T2 M2
  • STS T1 M1
I have several Semiconductor Test System (STS), and 1 STS is executing the test program much slower, even though they're all running the exact same version of the code, modules and TestStand. The STS that is slower is only slower when running in deployment. When running in development mode, it runs as fast as expected. What is the cause of this problem, and how can it be solved?
Ensure that the Multiple Threads option is enabled in LabVIEW Adapter Configuration from TestStand. See photo below:
