Self-calibration adjusts the PXIe-5831 for variations in the module environment using onboard power detectors. The PXIe-5831 modules are externally calibrated at the factory; however, you should perform self-calibration in several situations. For more information about these situations, take a look at the
Self-Calibration section of the PXIe-5831 Getting Started Guide.The main cause of this error is the wires of the system. If you are getting the message, NI recommends the following:
- If your PXIe-5831 includes the mmWave instrumentation (PXIe-5653 and mmRH-5582), disconnect it to reduce the scope of the error.
- If the error goes away, then disconnect all the wires in the mmWave hardware and reconnect them again. Try to run the self-calibration one more time.
- If the error doesn't go away, then disconnect all the cables connecting the PXIe-5820 and the PXIe-3622. Reconnect them again. Pay close attention to the connectors. You must hear a "snap" to identify if they have connected correctly.
- If the issue persists, try with a different set of wires for all the connections.
