Can I Change the Amplifier In My C Series Strain Module?
Updated Nov 18, 2024
  • C Series Strain/Bridge Input Module
  • I want to add a Carrier Frequency Amplifier to my Strain Module. Is this possible?
  • What type of amplifier is used in my C Series Strain Module and can I change it?
The amplifier IC (integrated circuit) inside C Series Strain Modules cannot be changed. The specifications for each module are defined based on strict test environments and the ICs that have been chosen for the device. Modifying the ICs in the device will void it's warranty.
The list below highlights the C Series Strain Modules that use a DC Amplifier:
