When I try to launch the UI Manager from VeriStand, it immediately crashes with the message
Veristand.UIManager encountered a problem and must exit.
When I check the crash log for VeriStand located at C:\Users\[your username]\Documents\LabVIEW Data\LVInternalReports, I see the following exception message:
ErrorId: 0xDEADBEEF
Error message:
The DateTime represented by the string is out of range.
Exception:
FormatException
Suggestion:
Contact National Instruments to report this error
