sbRIO-962x CAN Communication Has Incorrect Differential Voltages
Updated Apr 18, 2024
  • sbRIO-9628
  • sbRIO-9627
  • NI-Embedded CAN for RIO
I am using the onboard CAN port on a sbRIO-962X device. I am receiving invalid communication and measuring the differential voltages gives incorrect values for CAN communication. How do I resolve this and start reading/writing CAN data correctly?
This issue is caused by incorrect termination between the CAN_H and CAN_L signal wires that is causing reflections on the CAN bus. Ensure that the nodes at the end of the CAN bus are terminated correctly as per the specifications here.
