Cannot Adjust Camera Properties in NI-MAX
Updated Apr 3, 2025
  • Vision Development Module
  • Vision Software Suite
  • Vision Acquisition Software
  • NI-IMAQdx
I have run into a problem where I cannot see or adjust camera properties (both GigE and USB cameras) on some of my computers in our lab. The camera(s) show up in the list of devices in NI Measurement & Automation Explorer (MAX), but snap, grab, the tabs for adjusting properties, etc. are missing/not available.
How can I fix this?
This issue occurs due to the NI installer basically only installing the runtime version of IMAQdx, which does not include configuration abilities in MAX.
Install the full IMAQdx driver:
If you have the full IMAQdx driver installed on your machine and the issue still persists, you try the following:
  • Uninstall and reinstall the original driver of the camera.
  • change the driver for the camera in NI-MAX back to the original (IDS) one
