G Web Development Software cannot use Type Definitions on the Front Panel. If you need to do this, then using LabVIEW Web Services would be a better option.
As LabVIEW allows Type Definitions on the Front Panel, a LabVIEW Web Service can be called from the G Web Development Software. An example can be found
here.
