After creating or converting data into a
.digipatsrc file I want to import it as a Digital Pattern in my Test Sequence. I use the Digital Pattern Compiler command-line tool as described in the
manual.
I created in TestStand a Step
"Call Executable" including the following file pathname:
"C:\\Program Files\\National Instruments\\Digital Pattern Compiler\\DigitalPatternCompiler.exe"However, I get the following error message in the log:
"The system cannot find the specified path."
