The expected time for the timing card driver to generate the requested frequency using DDS is around 750 ms. An additional 3ms have to be taken into account for the routing of the generated clock to the ClkOut output of the timing card.
In a Semiconductor test framework, it is best to initialize and configure any step that takes significant time in the Process Setup sequence to avoid the module time impacting the actual main test.
