Configure the Debounce Filters on the PFI Lines of a PXIe-4309
Updated Jun 20, 2023
  • PXIe-4309
How can I configure the Debounce filters on the PFI lines of a PXIe-4309?
The PFI line of PXIe-4309 has two lines to receive the signal, one with a digital filter and the second without it.
rtaImage.jfif
And you can configure it as you want. For that, you need to enable/disable the filter, then choose the parameters that you need to set.
If you don't see the whole filter settings, so please follow this article: DAQmx Property Node is Missing Properties
Finally, you will be able to see the following configuration:
