String to Enum Conversion in LabVIEW
Updated Aug 30, 2023
I have read some data from the database and I am planning to insert one string to a LabVIEW enum control by using local variable. May I know how to convert a string value to type accepts by enum?
You can utilize Scan From String function available in LabVIEW to convert a string to enum type. Below is a simple example on how you can accomplish this.
string to enum
This function is case sensitive. Error 85 will happen if the string inputted is not exactly similar to any elements within the enum constant.
