Asynchronous Step Works Independently of the Sequence in the TestStand
Updated Mar 8, 2022
  • TestStand
To run the VI next to the normal sequence in TestStand to be able to monitor/debug.
To solve this issue, we need to execute a step asynchronously and change the settings of it.
We need to add a “sequence call” step to the test sequence and put our asynchronous step there. Also, we should configure the sequence call like is shown below:
  • Choose the right execution option:ansem.png
  • Then select settings:        ansem 1.png
  • From the settings, disable this step:        ansem 2.png
