Unable to Update Kernel Modules after Installing NI Linux Device Drivers
Updated Sep 29, 2023
  • NI Linux Device Drivers 2021 Q4
Other
Operating System: RHEL/CentOS 7.6
I download the NI Linux Device Drivers 2021Q4, then follow these installation instructions  and the NI-488.2 driver appears to have been installed without error.
However, when I try to update the kernel, it shows the following error below:
Error! echo
Your kernel headers for kernel 3.10.0-957.el7.x86_64 cannot be found at /lib/modules/3.10.0-957.el7.x86_64/build or /lib/modules/3.10.0-957.el7.x86_64/source.
This error is as below:
When opening GPIB Explorer  on RedHat 7.x, I received the following errors:
The attempted operation failed. libnipalu.so failed to initialize. Verify that nipalk.ko is built and loaded.
Failed to get all configured GPIB interfaces.
How can I resolve these errors and use GPIB Explorer?
The NI Linux Device Drivers 2021Q4 will install the latest kernel-devel which is not supported in RHEL/CentOS 7.6, so you are highly encouraged to use the newer version of RHEL or CentOS, such as 7.9 and above.
If you need to use RHEL/CentOS 7.6, firstly check the version of the system kernel release and the version of the installed kernel-devel. If they aren't the same, download the compatible version of kernel-devel and install it manually.
1. Check the kernel release version.
uname -r
2. Check the installed kernel-devel version.
yum info kernel-devel
3. Check if they are different and incompatible.
4. Download the kernel-devel-3.10.0-957.el7.x86_64.rpm online, and install it.
sudo yum install kernel-devel-3.10.0-957.el7.x86_64.rpm
5. Update the kernel modules again.
sudo dkms autoinstall
6. Open your GPIB Explorer and it should work normally.
