Does the NI-DAQmx for Linux/Windows support ARM architecture?
Updated May 13, 2024
  • Linux
Other
ARM Architecture
  • I want to use my NI data acquisition device on a device with ARM64 and Linux Ubuntu OS.
  • Does the NI-DAQmx for Linux support ARM architecture?
  • I want to install NI-DAQmx on a Windows Dev Kit (OS: Windows 11 ARM64), however, upon rebooting, the Windows failed to start and crashed completely.
The answer is No.
Based on the NI-DAQmx for Linux Readme , NI-DAQmx software for Linux supports only /x86 64-bit architecture.
As for Windows, NI-DAQmx does not support ARM-based PCs as well, and that’s the reason for the Windows crash.
ARM is a RISC architecture. RISC stands for Reduced Instruction Set Computing, while x86 is a CISC architecture, which stands for Complex Instruction Set Computing.
The ARM architecture is typically used to build CPUs for a mobile device, ARM64 is simply an extension or evolution of the ARM architecture that supports 64-bit processing. Devices built on the ARM64 architecture include desktop PCs, mobile devices, and some IoT Core devices.
Intel processor is based on x86 and x64 architecture.
