The NI-9237 is a ratiometric measurement device, meaning that it measures the ratio between the sensor output and the excitation voltage provided. The following link on
Bridge Sensor Scaling provides more information on ratiometric measurements. The module has both internal and external excitation options. The external excitation still needs to be routed through the module for an accurate ratiometric measurement. The excitation ranges are specified in the datasheet, note that the internal excitation has a maximum power of 150 mW. Full bridge sensors with a nominal resistance of 350 Ω or less requiring 10 V excitation will require an external excitation source.
