Error -1074395384 Invalid Color Template Image When Using Vision Assistant on myRIO
Updated Jun 2, 2025
  • myRIO-1900
  • myRIO-1950
  • Vision Assistant
The following error occurred when I execute Vision Assistant Express VI on myRIO :
This error is cause by insufficient memory when execute Vision Assistant on myRIO.
You can monitor memory usage on the RIO device or using breakpoint and highlight execution to monitor insufficient memory error.
This error can be solved by using RIO device with larger memory or optimize LabVIEW coding.
