This article will explain how to route a signal from a PXI(e) SMU card to the backplane trigger lines on a PXI(e) chassis. This process involves using the
NI-DCPower VIs to export the SMU signal onto a PXI_TRIG line.
Before proceeding, ensure that a compatible version of
NI-DCPower is installed on the development PC. Refer to the NI-DCPower readme document from the
NI-DCPower Release Notes for a list of compatible hardware.
