Rename device name with nidaqmxconfig on Linux Desktop
Updated Oct 29, 2024
  • Linux
This article will go through the steps of renaming the alias of a DAQ device on a Linux desktop.
After installing DAQmx on a Linux Desktop, you could use nidaqmxconfig to rename the alias of a DAQ device.
  • Use nidaqmxconfig --export <file name> to export the settings.
  • Edit the exported file and change the alias of the device.
  • Use nidaqmxconfig --import <file name> --replace to replace the settings.
After applying the steps above, the alias of the device could be renamed successfully.
