Can I Transfer Files Using the LabVIEW OPC UA Toolkit VIs?
Updated Nov 2, 2023
  • LabVIEW OPC UA Toolkit
  • I want to share files between my OPC UA Server and Client. Is this possible using the OPC UA Toolkit?
  • Can I use UPC UA VIs to transfer files from a cRIO Server?
  • How can I transfer file from an RT Target to a Client using OPC UA?
  • I need to programmatically transfer files using the OPC UA protocol in LabVIEW™. How can I do this?
As of LabVIEW and LabVIEW OPC UA Toolkit version 2021, there are no native VIs that allow for file transfers within the LabVIEW OPC UA Toolkit. For a list of included VIs and their functionality, see OPC UA VIs.
If using a Linux RT Target as a Server or Client, NI recommends the following alternative methods: For a detailed explanation of each of these methods, refer to Tools Available for File Transfer/Access on NI Linux Real-Time Targets .
