For New Projects, a Modernized Toolchain Is Advised Instead
This article explains how to use Eclipse C/C++ Development Tools for NI Linux Real-Time to achieve cross-compiling tasks. This toolset is not actively maintained anymore. It was last updated in 2018 and is currently not advised to be used for new projects.
Instead, NI created extensive documentation for a modernized toolchain, which is easier to learn and utilize. That documentation also provides information on typical steps, like building, deploying, and debugging a shared library. If you are planning to do C/C++ development and are searching for the right toolchain, then visit Getting Started with C/C++ Development for NI Linux Real-Time.
Overview of the Following Eclipse-Based Content
I have a C++ application developed with NI Eclipse and need to deploy the FPGA lvbit file to the sbRIO board during application startup. I have created a start up script to auto run the application, after the sbRIO board power up the lvbit file was not downloaded successfully and causes error below :
Error -63101 NiFpga_Status_BitfileReadError
