Component Simulation Model Not Available in Multisim
Updated Apr 21, 2022
  • Multisim
I have created a circuit using Multisim, but I cannot perform a simulation as the SPICE models for some components are missing.
Use an older version of Multisim and add the components to an empty circuit and export them to the version that you are using.
Most of the time you can find the components with their SPICE model in older versions of Multisim for example in Multisim 11.
However, if you have access to the component's SPICE model you can manually add it with the help of this article.
