Is It Possible to Install Multiple Web Applications on a SystemLink Server?
Updated Oct 27, 2026
  • SystemLink 2020 R1
I have a Web Application created using LabVIEW NXG Web Module (G Web Development Software) that is registered and used as a SystemLink Web Application. When I created multiple applications using the procedure and template described in this document and installed them as SystemLink Web Applications, the previously installed Web Application was overwritten.
Is there a way to install multiple Web Applications as SystemLink Web Applications?
When a created application is installed as a SystemLink Web Application, a folder with the name specified in the configuration file (the template default is webvi_plugin) is created in the plugins directory under the following path, where components hosted by the NI Web Server are stored:
C:\Program Files\National Instruments\Shared\Web Server\htdocs
You can install multiple Web Applications by changing the folder name.
The values highlighted in red in the following five configuration files must be changed from the default name. In this example, the default value is changed from webvi_plugin to webvi_plugin0.
webvi_plugin0 becomes the installation folder name, and WebApp0 becomes the display name of the SystemLink Web Application.
