Vector Label Exceeds Limits When Importing a Digital Pattern Source File
Updated May 1, 2023
  • PXIe-6571
  • PXIe-6570
I need to use a .digipatsrc file in my digital pattern project. When I use the import tool to convert the file into a pattern, I have the following error: Vector label exceeds the allowed limit of 8191
How can I use my source file?
The compiler used by NI Digital Pattern Editor has a limit of 8191 vectors with a label. You need to remove the extra labels in your source file if you want to convert it.
