What Arguments Can I use with TestStand MSI Installers?
Updated Feb 19, 2025
  • TestStand
I am building a MSI installer from the TestStand Deployment Utility. What arguments can I use when installing this built installer through the command line?
The TestStand Deployment Utility builds a normal MSI installer that Windows will install through the default msiexec.exe software. As such, you can use all normal Windows MSI installer command line options, which are detailed in the Microsoft article "Microsoft Standard Installer Command-Line Options".
