NI Package Manager CLI Does Not Find Packages After Adding Feed
Updated Feb 17, 2022
  • Package Manager
I am using the Command Line Interface of NI package manager to automate installation of my company's internal packages.
After adding the feed via nipkg feed-add [...], I call nipkg install my-package. Then I get the following error message:
Unable to locate package 'my-package' with a compatible version and architecture.
After adding a feed via CLI, you need to run the nipkg update command once, so that NIPM collects the information about the available packages in the freshly added feeds.
If you use the GUI of NIPM instead of the CLI, NIPM automatically updates its data after a change to the feeds.
