Why do Kunbus C-Series PROFIBUS and PROFINET Modules Need An Empty Slot?
Updated Apr 28, 2023
  • C Series PROFINET Interface Module
  • C Series PROFIBUS Interface Module
Kunbus C-Series PROFIBUS and PROFINET modules state they should be placed in slot 1 with an empty slot 2. Why is this?
Kunbus C-Series PROFIBUS and PROFINET modules use an excess of power compared to other C-Series modules. This results in generating a large amount of heat which will affect neighbouring modules, and as such may take these out of specification.
The reason for using Slot 1 is that this is common across both 4-slot and 8-slot and requires minimal API change.
