The maximum number of NI SMU to be cascaded depends on two criteria:
- The highest voltage from ground, VDC (which could be found in NI SMU specification).
- The maximum outputĀ of NI SMU.
For example, I have a
PXIe-4145 and I would like to have a 100V differential, then I could cascade these PXIe-4145 in a way that several to reach +50V, and another several to reach -50V, both relative to ground. Since this does not exceed the highest voltage from ground. 60 VDC as stated in the
spec .
